which is the superior in ceiling speaker
markyboy156
203
hi all
which is the superior in ceiling speaker for sound quality bass and wide dispersion ef
fect the rbh mc-815 or
the kef ci200rr for atmos dts x auro3d 3d effect
used with rbh impressions speakers package thanks
ideal av
i'd check out the Dali Phantom range, i've been installing these now for about a year and they are the best i've heard to date and still affordable with good build quality
its pointless recommending speakers that are unaffordable
ideal av
buzz_lightclick said:
Would you recommend the Dali Phantom E80?
I'm also looking to upgrade my ceiling speakers, would have liked the Kef THX ones but at £475 each too expensive!
i certainly would, maybe a little overkill for overhead atmos duties but very good, the E60's are more than capable if i'm being honest with you, and the E80's are obviously better, how large is your room and whats your ceiling height?
i've used both quite a few times now with very good results, get in touch if i can help you further
Allan
