- Jan 20, 2012
- 21
- 0
- 0
I am looking for a piece of kit that will play music directly from a USB stick or similar. I don't want to spend more than £300 and would try to buy used for less than that. Are there any suggestions, does such a thing exist?
charlesrichardson said:I am looking for a piece of kit that will play music directly from a USB stick or similar. I don't want to spend more than £300 and would try to buy used for less than that. Are there any suggestions, does such a thing exist?
lpv said:look for japanese all in ones from marantz ( m-cr510) or denon.. or a/v receivers..
iMark said:charlesrichardson said:I am looking for a piece of kit that will play music directly from a USB stick or similar. I don't want to spend more than £300 and would try to buy used for less than that. Are there any suggestions, does such a thing exist?
There's quite a few.
Denon DCD 720AE, Pioneer PD10, Yamaha CDS300. I'm sure there are more.
gasolin said:With a budget of 300£ it's a no brainer Marantz CD6005 alone the fact that it's the cdplayer of the year in it's pice class for the 3 time doesn't make it hard to choose which one to buy
Covenanter said:The Marantz kit will play from a USB Stick but don't expect any great flexibility. You can play "all" or you can skip around from track to track but there isn't any way (that I can see) of finding specific tracks.
Chris
