Which cables for Tannoy XT8F
loneranger
27
I'am looking for cables for my set; Tannoy xt8F, MF M5si amp, Cambridge cxn sreamer. I play a lot of metal and rock, but never hard. Unfortunately not the best recordings. Which cables will be the best match? I was looking at:
Van den Hul D352 speakercable with D102 interconnect
Chord Clearway speakercable and interconnect
QED XT40 speakercable with their reference interconnect
abacus
Pop along to you nearest Pro Music Store (Or online store) and get your cables from there, that way you will get the same cable as used by the Pro Studios to make the music you listen too, and will be a fraction of the price and much better quality then the cables that Hi-Fi cable manufactures try and con you into buying. (The money you save can be spent on more music or room treatment, which will really make a difference)
Bill
nick8858
29
Follow the advice of Abacus. Chasing the dream of audio perfection through excessive expenditure on a piece of wire will not get you to audio nirvana.
macdiddy
87
especially abacus and his cut and paste reply he uses with everyone who dares to ask a question about cables.
do what you want, check out some cables, its your money, spend it on what you like.
*music2*
CnoEvil
556
14
FWIW. I'd look at Linn K20 S/C and either Linn Black or Linn Silver I/C...usually good value from Ebay.
Of the ones you've listed, I'd rather have Van den Hul (but that's me).
loneranger
27
I could try a second hand Van den Hul the royal jade hybrid speakercable. Much nicer sound than with my 2,5mm Van damme speakercable. I can't explain it, but it sounds realy better. I will now go for the Van den Hul D102 interconnect.
