Which amp to buy , denon3312 or pioneer LX75
Please can someone advise . I don't know whether to buy denon3312 or pioneer Lx75 , I have kef iq30 s at the front ,centre speaker is iq60 & side and back speakers are kef eggs 3005se with sub .
michael hoy
Have you demoed either of the amps.
Not heard the Denon, but do have a lx85 and previously had a lx72 and a Denon 1909.
I did prefer the Pioneer sound over the Denon, only you can really decide by listening your self.
Thanks for your advise ,I haven't listened to either of them ,my rooms 3meters by 4meters do you think the LX85 would be to powerful for my speakers &roomsize .
Big Aura
522
10
18,895
hello
I previously owned a pioneer VSA-EO3 and bought a Denon 1909. I never liked the Denon. When it came to upgrade, I really wanted the Pioneer LX73 (precursor to the 75). I demo'd the 73 and used the Denon 3312 as a 'stalking horse' on the basis that it was the best Denon currently available, so would sound similar to (but better than) my 1909, but would show the LX73's class.
I bought the Denon (much to my surprise!).
Please audition both (and a comperable Yamaha and Onkyo).
Good luck!
michael hoy
My current room is 4x4.5 mtrs with a large opening to one side into the dinning room.
The extra power helps drive the speakers at lower listening levels and gives the control I was looking for when needed.
My amp is normally at -36db for most movies and can go upto -26db for music depending on the source.
The 85 does sound slightly different to the 72 I had previously tonally, it was never bright as some would say, but the 85 has a slightly warmer sound.
Denon amps do have a warmer sound than the Pioneer, again you would have to demo yourself if possible.
One thing, make sure the dealer has calibrated the amps before you listen, I had a demo not long ago and whilst the dealer was out of the room I checked the amp settings, only to find they were still at the factory default.
