Hi, I'm looking for 5.1 system to upgrade. My room is 3.3M back to front and 3.2M side to side and 2.4M high. The amp I have is the Onkyo TXNR 807 and use the Chord Carnival Silver Screen Speaker cables with QED screw-loc banana plugs, Chord Crimson Plus Sub cable and Chord Super shield 3D ready HDMI.
The fronts + rears and centre will be wall mounted using the appropriate bracket supplied by manufacturer.
budget £700
WHARFEDALE DIAMOND SW150, WHARFEDALE DIAMOND 9.1 X4, WHARFEDALE DIAMOND 10CM CENTRE.
CANTON MOVIE 125MX
Q ACCOUSTICS Q7000
Q ACCOUSTICS 2000I (NEW)
Q ACCOUSTICS 2000
MONITOR AUDIO BR2 AV 5.1
TANNOY HTS 101
Thanks for any help, ADE
budget £700
CANTON MOVIE 125MX
Q ACCOUSTICS Q7000
Q ACCOUSTICS 2000
TANNOY HTS 101
