what turntable would suit a marantz pm6003
I am thinking about buying the classic marantz cd6003 and marantz pm6003 set up. Any advice on what would be a good turntable to match. I would be mainly playing vinyl so would allow a budget of upto £500.
I had the same combo for 6 months and was perfectly happy with my pro-ject debut in that set up.
I'm sure others would probably suggest the Rega P2 or P3. Plenty of other options if you go 2nd hand.
Yes, 500 quid will buy you a lot of turntable, especially second hand. In fact, I went digging to see what was available and I want a turntable again. Besides the obvious Rega and Project decks you can buy new for that money, there are some incredible bargains on the second hand market. A clearaudio solution with origin live arm - the second most beautiful turntable in the world - just went for 650 quid on eBay, which is amazing, I just sold my Project RPM5.2 for less than 250 quid, and the local hifi shop has a Rega P25 (kicks P3 butt) for 400 quid with a short warranty. So that gives you an idea of what's available within budget.
The phono stage on the Marantz is a good starting point, but obviously a better deck will benefit from a better phono stage in the fullness of time.
