What to do what amp.?
Hi all as you can see my user name states it all I have just had a clear out and and want to start again so what I have left is two Nad monitor series 2400 power amps and an old yam pre amp model e800 I want to play my tunes through my iPod iPhone can I do this with this old pre amp.?Next question is this pre amp suited to these power amps.Next question can I run small speakers with a separate sub.?If I need to buy a new pre amp this is no problem.Many thanks SImon.
Here's the spec of the amp taken from the NAD website:
POWER AMP SECTION
Continuous output power into 8½ * 100W (20dBW)
Rated distortion (THD 20Hz - 20kHz) 0.03%
Clipping power (maximum continuous power per channel) 130W
IHF Dynamic headroom at 8½ +5.7dB
IHF dynamic power (maximum short term power per channel) 8½ 370W (25.7dBW)
4½ 400W (26dBW)
2½ 440W (26.4dBW)
Damping factor (ref. 8½, 50Hz) >100
Input impedance 20k½ / 600pF
Input sensitivity (for rated power into 8½) 1V
Frequency response 3Hz - 100kHz / +0, -3dBdB
Signal/noise ratio ref. 1W 98dB
ref. rated power 118dB
THD (20Hz - 20kHz) <0.03%
Bridged Mode
Continuous output power into 8½ * 200W (23dBW)
IHF Dynamic headroom at 8½ +6dB
IHF dynamic power (maximum short term power per channel) 8½ 800W (29dBW)
4½ 880W (29.4dBW)
PHYSICAL SPECIFICATIONS
Dimensions (W x H x D) 435 x 127 x 385mm
Net weight 10kg
Shipping weight 12kg
Power consumption (120 ~ 240V, 50/60Hz) 390VA
* Minimum power per chnnel, 20Hz - 20kHz, both channels driven with no more than rated distiortion.
Dimensions are of unit’s cabinet without attached feet; add up to 18mm for total height.
Dimension depth excludes terminals, sockets, controls and buttons.
© NAD
