what subwoofer cable?
markyboy156
203
hi can anybody recommend me a sub woofer cable to go between my onkyo 5009 and rxw12 subwoofer please could somebody reply asap please?
Tbh, there's not a huge amount of difference (that I've heard) in sub cables. Personally, I would want to spend anymore than £40. Chord Crimson would suffice!
BenLaw
475
7
18,895
Buy some pro cable for < £10 from ebay. That's what will have been used in the studio to master anything you might be listening to. Buy some blu rays with what you saved :)
chudleighpaul
129
Very good advice.
Don't get ripped off by the snake oil pedlars.
QED Signature, worth every penny. Stonking cable. Before you upgrade your cable though, i would buy a granite chopping board to place your sub on. The best upgrade for your money there is! :dance:
CnoEvil
556
14
super said:
Hi Gander, where did you get your granite chopping board from and how much was it ?
I'm afraid I'm not Gander, but there's one on sale here:
http://www.argos.co.uk/static/Product/partNumber/8423689.htm
They can be very effective, along with a mains cable like the Copper line Alpha from Clearer Audio....on sale at the moment here (scroll down the list a bit):
http://www.cleareraudio.com/onlinestore/Copper-line_Alpha_Clearance_Cables.html
CnoEvil
556
14
super said:
That board looks good and surprisingly cheap. I winder if it would be ok to support 2 x M&K 350's subs which are quite heavy.
I don't think the weight would be a problem, but I think the sub dimensions might be: 15.3" x 20" (39cm x 51cm). The granite is 30cm x 40cm, so you would need 2 (side by side) per sub. Try one sub first, to see how you get on.
ps: for those i would go to a local stone mason / specialist and get him to make you up a couple that are thicker, heavier and cut to size. Would still be worth it IMHO.
super
57
Unfortunetly i can't have them side by for space reasons. I did have one on one side of the room, but they sound better together. And as they stand at the moment one is on top of the other, that's why i was concerned about the weight.
CnoEvil
556
14
In that case I would use one of these on the bottom, which are better than Granite anyway, and are rated to 300 lbs:
http://www.dolphinmusic.co.uk/product/36069-auralex-gramma-amp-monitor-isolation-riser-single-.html#sterling_uk
