What setting do i use to upscale to 1080p on ps3. is it double-scale?
Andrew Everard
1,878
From the manual:
"DVD Upscaler
Adjust settings for upscaled output when playing a DVD. Upscaling is
a feature that can be used to enable content recorded at SD resolution
(NTSC: 480p / 480i, PAL: 576p / 576i) to be displayed in HD resolution
(1080p / 1080i / 720p). Because the video content of commercial DVDs is
recorded in SD resolution, higher resolution video can be achieved by
enabling upscaled output.
Off
Set to disable upscaled output.
Double Scale*
Set to upscale and display with double horizontal and vertical dimensions without changing the proportions.
Normal
Set to upscale and display at a size that matches the screen size.
Full Screen
Set to upscale and display at full screen by changing proportions and stretching the image
This option can be used only when the video output setting of the PS3T system is set to 1080p or 1080i.
Hints
  • To use this feature, a TV that is compatible with HD input and
    output must be connected using an HDMI or component AV cable. Also, the
    video output setting of the PS3T system must be set to 1080p, 1080i, or
    720p.
  • When playing copyright-protected DVD content such as commercially
    available DVD-Video, an HDMI cable is required to upscale the video
    content.
  • If image quality is reduced or the image does not look right when upscaled, set this option to [Off]."
I'd use Normal...
FoxJA
42
[quote user="Andrew Everard"]
From the manual:
[/quote]
Manual? is that what it's for. I'll have to read one of these manual thingy's one day.
[quote user="FoxJA"][quote user="Andrew Everard"]
From the manual:
[/quote]
[/quote]
Only as a last resort if all else fails I presume !
