Good Evening.
Firstly I'd like to thank those who contribute to this forum there is a wealth of information so much so my mind is going crazy, this is my first post but I shall attempt to put in as much information as possible.
I've recently move into a new property and I'm looking a HD TV for the living room.
The following devices will need to be connected:
Mac Mini - HDMI/DVI/Composite/S-Video
Sony DVP-NS 700V DVD/SACD Player
Sony STR-DE475 AV Amplifier (Composite Video Monitor Out Put Only)
Sky+ (Not yet ordered so not sure on connections)
I'm happy for each of the Video devices to be connected directly to the television and use the amplifier for audio switching only as I want to get the best quality video from each of the devices.
The room is 19feet/16feet. the TV is to be wall mounted and will be mounted above the fireplace the sitting distance from the fireplace is around 8' 6".
My primary use for the screen will be normal SD broadcasts from the Sky+ box, DVD's (later on I will be getting a blue ray player/DVD recorder), some computer use from the mac mini with a wireless keyboard but the main use of the mini is for my DVD collection that I'm slowly importing as well as my large music collection, I intend to use Front Row/Media Central as the front end to my music and video/tv shows from the states.
I have been looking at 37"/42" sizes, should I be looking at support for 1080p?
What brands do you recommend and what should I avoid?
Should I look for Plasma or LCD from what I understand Plasma are better at producing darker scenes and do a better job of smoothing SD broadcasts and fast action movement.
Any information you can provide would be gret.
Many Thanks
Rich
Many Thanks
Rich
