WHAT CD PLAYER WITH ROTEL RA06SE? Any suggestion folks ? Thank You for help
domenn
42
hello , I have a dilemma
, what cd player would be a best maching to my rotel ra 06se.? At the moment I'm using
CD Cambridge audio 340c (coax) Caiman DAC (crimson plus) chord odyssey 2 B&W 601s3. It sounds little bright ,how to achieve a bit warmer sound with better midrange . Rotel amp is about 2 weeks old and speaker cables about 3 days
Do You think the amp is still in burn in period ? and I should wait couple of weeks?
I consider about new cd player anyway , marantz cd6003 , nad c545bee , rega apollo , which one would make my set up little warmer? in future want to upgrade speakers (probably b&w684 ) thank You for suggestions folks
Hi domenn
From my experince the Nad is the warmest sounding cdp out of the 3 have owned all 3 of them. Also give the amp and speaker cable time to burn in. You may just need time for the system to settle.
Best regards
Gtncj.
hello Gtncj , Thank You very much for your response I will consider Nad 545 Bee but I see how price gone up
I remembrer it was about 270£ 2 months ago , but also I am awarwe of not the best reliability of Nad's Maybe I'ii be the lucky one
if I'll go for NAD
The NAD C545 CD player would be my suggestion for warmth. There was a batch over a year ago that had some issues and NAD were swift and efficient in resolving these. We had a few back and repaired at the time but since issues have been rarer. Build quality overall is excellent. It's also worth listening to the Yamaha CD-S700 which isn't as warm but does have a very neutral sound as another impressive player in its class.
Hi domenn
Aparently there was some issues with some of the switches and ic10 but a Nad rep has said to me these issues have now been resolved.
The most important thing is what you think and always try and get a shop demo or a home demo as the home listernig enviroment has a major role in the final decision.
why a cd player?
rega dac is a nice one! buy an Imac put all your cd's lossless in iTunes and buy an Ipad as remote
no just joking, if already owned an Imac+iPad so that's why I choose to stream.
I think Rega Apollo is a great buy if you want a cd player, but marantz has some nice players too.
