what cables?
scene
To do full 7.1, you'll need 4 pairs of RCA/Phono cables. If all you want is 5.1, then 3 pairs will suffice.
BTW: I use 4 pairs of Chord Crimson (not plus). I got mine on eBay to keep the cost down...
scene
NB: The Mark Grant / Blue Jeans custom cable is available as a 5.1 or 7.1 option. You can still use a 7.1 connection, even if you've only got a 5.1 system. I believe your amp will downmix it to 5.1, otherwise you can have your BDP do it (think that's right). I get my amp to do it.
Wouldn't worry to much, and there aren't that many 7.1 BDs around
John Duncan
Mav - don't know if you've been misled in your other thread but your current player doesn't have multi-channel analogue outs. If you've bought another (not the 770 because it doesn't either).
Think you need to sort out your other issue before buying anything else...
JohnDuncan:Mav - don't know if you've been misled in your other thread but your current player doesn't have multi-channel analogue outs. If you've bought another (not the 770 because it doesn't either).
Think you need to sort out your other issue before buying anything else...im sure mav knows his current player doesnt have multi channell analogue outs, cos i told him that...
and im not sure why he would have bought the 770, because nobody mentioned that, apart from you
