Is the the 12 series Wharfedale positioned a step above the 11series ? The prices seem to be similar .
Just the latest iteration of the long-running Diamond series.Is the the 12 series Wharfedale positioned a step above the 11series ? The prices seem to be similar .
I thought the long running 200 series was replaced by the 11 . Was surprise that another 12 series added.Just the latest iteration of the long-running Diamond series.
A complete redesign though apparently.
I believe the 200 series were a completely separate line.I thought the long running 200 series was replaced by the 11 . Was surprise that another 12 series added.
200 series is also Diamond series as stated in Wharfedale website.I believe the 200 series were a completely separate line.
The Diamonds have always been 10, 11, 12 etc and this is there 'compact' line.
It's complicated when you use Diamond in multiple lines but it differentiates from the Jade series.
Thank You .The Diamond 12 series directly replace the Diamond 11 series.
Thank You .
Now i get it (So its 225 > 11.2 > 12.2 progression as per series?)
Looks like 12 series is back ported . Maybe its easier to manufacture and most Fink designs are backported ?
Iam using 11.2 . Guess there may not be comparison wrt 11.2 even though WHF did a 12.1 review. Hope some users can share their views.
pre-Diamond is probably before many forum posters were born.Nice to see the company (name at least) still going strong.
I was using their Glendale's in the pre-Diamond days.
The 200 was not replaced by the 11 they ran concurrently and are different lines.I thought the long running 200 series was replaced by the 11 . Was surprise that another 12 series added.
I am old enough to have used Wharfdale speakers before the term Diamond was ever used....pre-Diamond is probably before many forum posters were born.
I still use my wharfedale 1s as computer monitors, but after nearly 40 years I do prefer other speakers.
Even so, a simple chord mojo plus early wharfedale speakers, will still kick the ass of most other computer monitors.
The 225 was always a completely different range.
Think 9,10, 11 ,12 ......
From 10 onwards they have been rear ported.
Thank You .
Thank you for the response.Useful overview.Fink Audio designed the mid/woofer drivers only. The rest of the design and build is Wharfedale's. They decided to go back to rectangular box design, with additional internal bracing to minimize speaker resonance, something the curved, reducing speaker box design does well and addresses on its own. The bottom firing port has now been replaced on 12 series back to a traditional back firing. The measurements done on the 11 and 200 series proved the bottom firing port allowed for further bass extension, now 'lost' in the 12 series.
The tweeters on 12 series are now also simplified, gone is the WFR design with its own closed type vented enclosure which separates the tweeter from the rest of the speaker cavity.
The 12 series is also more affordable than 11. I see it as a 'budget D11', while I see D11 as a 'budget Reva'.
The reduction of manufacturing steps and materials used in its production reflects that. Yes, it admittedly punches above its weight, but so does D11, and many other Diamond series before.
To me the D12 looks and feels as a an upgrade to the outgoing D200 series which was already fantastic performer in its price range.
The 11.2 i have on tweeter does not have the print "WFR vented system" but just the W logo. The pics shown on the Wharfedale website has both . Does this mean i got a ver2 -11.2 - tweeter which may or may not have the WFR vented system. I asked Whafedale who directed me back to local dealer who mentioned that some of these aspects change . I think a company like IAG-Wharfedale can do better to update info on website or social media channels
Note the ver2 tweeterReally sorry to hear that. My 11.2 has both the W logo and the WFR inscription on the tweeter beauty ring.
I think yours is like this one:
View: https://www.youtube.com/watch?v=ur0Yp26gUys&t
If you look at the comments I asked few days ago how come the tweeter on the 11.2 doesn't feature a vented isolation cap on the back of the tweeter's magnet, they also didn't know. It appears as you stated the Wharfedale changed the specs along the way
I am not surprised though, Jamie O'callahan, Wharfedale's marketing manager, stated on one of the YouTube channels the D11 series was a loss leader for them, over-engineered and under-priced, this was basically their attempt to get the award wining Diamond series back in the spotlight, which they lost in Series 9 with well documented and reported blown rubber rings on the bass drivers, something the series 10 that followed never managed to 'rectify' in regaining Diamond's once well known and regarded popularity.
11 series went way over the top for a budget speaker line, it's basically a Reva 'on a budget'.
Still, even with a 'downgraded' tweeter design, it's a heck of a speaker you own.
EDIT: The mistery continues...
Here is a photo of mine, now 2 years old (let's call it V1) - first attached photo.
The "new" current (V2) is attached as a second photo that I found on the web, which shows the full system.
If you pay attention you will notice mine comes with the WFR inscription but also a much larger plastic and metal beauty rings around the tweeter. Compare it with the tweeter on the second photo which shows "D11.2 V2" and you will notice how much is the "V2"tweeter ring smaller and it lacks the WFR text as you pointed out.
It also appears on the V2 the woofer was 'lifted' a little higher on the front baffle as it's at the same distance from the tweeter silver circle as on the V1, which features larger tweeter ring.
One more thing I noticed but could be wrong, the woofer foam surround has now been replaced with a rubber one? What does it look like on yours?
This is what I found on the Wharfedale website describing Diamond 11:
"Then there is the progressive suspension which features a lightweight RUBBER surround for an extended midrange response, in conjunction with a super-long-throw voice coil motor system... "
It used to say:
Then there is the progressive suspension which features a lightweight FOAM surround for an extended midrange response, in conjunction with a super-long-throw voice coil motor system..."
Also, gone is now the WFR description they used to have for a tweeter along with the picture that shown exploded tweeter blueprint with the isolation cap at the end.
Keep us posted please, cheers.
Mid/woofer Looks and feels like rubber
The build quality and curved cabinet is done well
Something I never appreciated until I read an informative post about it is a mass manufacturer‘s production methods. Ranges like these might be made in one run, of say 20,000 pieces in PRC. Within that total number an estimate on which sizes will be most popular is made, and built accordingly
Once that run is nearing sell out, say after three years, they either need to make the same again, or more typically release a v2 or a new range. That’s what may be the case here, with economies as required to return to profitability.
Thank You .
Most reviews in hifi mags were done using ver1 .At least thats what I could observe.Maybe the dealers were alerted or maybe not until eventually the information got around.I did buy anticipating i would be receiving the ver1.That's correct. As an example, if you happen to purchase products from places like AliExpress etc, you would have come across the situation where the product you receive differs sometimes greatly, from the product advertised by the seller. Manufacturers often update design, production methods and materials without always letting the end retailer know of the changes.
While superb in their own right and punch way above their weight, Diamond line is still just an entry level product in Wharfedale portfolio, the one they count on selling in larger numbers than other speaker lines of theirs.
Unfortunatelly, while they sold truckloads of D11s over the last 3 years, they reportedly and admittedly made little or no profit on them, so somethimg had to change after their account team would have intervened.
Also, they're toutung the latest D12 to be the "best Diaminds ever". To be able to do so and go against the fantastic predecessor which is 11s, something had to give They simply made the 11s slightly less attractive an option now.
Some of this above is my own observation and ramblings, but having been into this hobby for many years and having owned multitude of Wharfedale speakers, I believe I am not far from the reality here.
Cheers.
Specifications | |
Description | 2.5-way floorstanding speaker |
Bass Driver | 5"(130mm) Woven Kevlar Cone |
Midrange Driver | 5"(130mm) Woven Kevlar Cone |
Treble Driver | 1"(25mm) Textile Dome |
Sensitivity (2.83V @ 1m) | 90dB |
Recommended amp power | 25-125W |
Peak SPL | 102dB |
Nominal impedance | 8 Ω compatible |
Minimum Impedance | 3.9Ω |
Frequency Response (+/-3dB) | 44Hz ~ 20kHz |
Bass Extension (-6dB) | 35Hz |
Crossover Frequency | 3.1kHz |
Cabinet Volume (in litres) | 29.2L |
Dimensions (HxWxD) | (875+25) x 194 x (285+38)mm |
Net Weight | 13.8kg/pcs |
Specifications | |
Description | 2-way bookshelf |
Bass Driver | 6.5"(150mm) Woven Kevlar Cone |
Midrange Driver | |
Sensitivity (2.83V @ 1m) | 88dB |
Peak SPL | 96dB |
Minimum Impedance | 4.2Ω |
Frequency Response (+/-3dB) | 48Hz ~ 20kHz |
Bass Extension (-6dB) | 40Hz |
Crossover Frequency | 2.6kHz |
Cabinet Volume (in litres) | 13.2L |
Dimensions (HxWxD) | 355 x 221 x (290+32)mm |
Net Weight | 7.4kg/pcs |
