Wharfedale SW250 - have I bought myself a bargain?
kingnothing83
56
Just bought one which is in perfect working order, with a couple of small marks on the front (which hopefully i can repair or cover up in some way, they looked very small) for £110 from ebay. The slight damage wont affect sound they say and it seems like a trustworthy source with plenty of feedback all 100%. Sounded like a bargain to me so i went for it to be part of a home cinema system i havent even bought yet!
Any thoughts on it? I was looking for a sw150 but this went for what looks like a great price and has extra options and a remote. This drives the bass downwards, is this likely to be more annoying to neighbours than a front facing sub? May have to be careful i knock the volume down 🙂
Also ive been offered this MonsterBass™ 400 Subwoofer Interconnect http://www.monstercable.com/productdisplay.asp?pin=1061 a 12ft one for £20 by the seller - is this a good way to hook up the sub? Worth taking?
Simon
Bargain. If you aren't bothered by the damage who cares. You've just saved yourself £150!
Personally I dislike Monster because they constantly churn out lower grade cables for much money indeed. Try Chord Crimson, a cable with far more pedigree. Failing that Profigold cables will match Monster for less.
Make sure you audition it first before paying for it. Long trip back if you get it home and find it's a clunker.
