Weakest link in my chain
Vizzage
14
Helloooooo!! Just wondering what you guys and gals would say is the weakest part of my system and what I should perhaps upgrade it to? It's in my sig 🙂
Oh **** I just bought the castle howards! The rega planar 3 is on the other hand the oldest item in my system, though it has had the full works dine in it by SRM-Tech. I think it needs a better cartidge. So what speakers would justify the rest of it? Lol jjbomber by the way 🙂
The Howards a lovely speaker... I thought perhaps the CDP or tuner amp.
What's your budget?
Do you like a warm lush sound, or more neutral?
Mac
Speakers, amp, CD player etc are all fine, a really good system. The only thing I'd look at would be the Planar, which really need wall shelves.
Don't know the SRM-tech, thing, though.
P.S Speakers are really good, full, rich sound. Only change them if that's not to your taste. Detail rules today.
The Howard S2s are great speakers. Don't change them in a hurry.
I wouldn't rush to change anything to be honest. You have a great system there. Maybe a new cartridge for your Planar 3 and, as altruistic.lemon suggests, a proper wall support for it.
Is there anything you particularly find lacking about the sound of your set-up? If not, leave well alone.
Thank you for your comments! Phew.
Yep the rega's already on a wall shelf so I'm just do the cartridge and a DAB tuner and relax for a bit!
