Watching Netflix on Samsung Q60 Tv using Sony WH-1000XM4
swingman
I recently purchased This headset to watch Netflix etc on my Samsung Q60 Tv. After pairing it seem to work perfectly for 80 to 90% of the time. From time to time, I get a continuous crackling noise with interfering with the sound and almost impossible to follow the dialog. Normally it runs for few MI Utes or sometimes it disappear when you rewind a bit and replay it. This implies there is no defect in the output from TV. If I disconnect the headset and play the same passage in the TV the sound output is ok.
Is my M4 is faulty or its common?
swingman
gel
Moderator
I have used the Sony 1000 3 the generation before yours with the Samsung 65q950R and it worked fine but very quiet though. I can recommend some headphones that work better for this kind of function see here:
MR_T
I just bought these headphones and have the same tv and setup and have this exact issue. The headphones work fine with everything else except when streaming Netflix. Did you manage to get this resolved ? BTW, I also have the XM3 and no issues with that one.
ASK THE COMMUNITY
