My Quad 405 sounds a bit brittle and harsh. It has superb midrange and lots of detail but is a bit lean in the bottom end and fatiguing.
My Rotel RA03 has a very well judged tonal balance and is the warm side of neutral in comparison to the Quad. Criticisms are a slightly bloated bottom end and a slightly veiled midrange. Very enjoyable to listen to for hours on end but struggles to make sense of the mids sometimes.
So with a budget of something like £1.5k what should I consider replacing them with?
i) Netaudio Quad 405 MK3 overhaul for £400 matched with a carefully selected, used tube pre (e.g. Conrad Johnson PV10AL, Trilogy 902 Pre)
ii) Used Primare PRE30 and A30.2
iii) New Primare I30
iv) Some sort of used valve integrated with a bag of power (40W+)
v) Krell 300i (random but I've seen one up for sale recently)
vi) Unison Unico hybrid
vii) Other...
Option i is current fav as I think it might work really well. Problem is, I can't try the Quad upgrade before buying.
Has anyone any thoughts, opinions, advice? I listen to all types of music, love decent midrange and hate brightness, harshness or boominess. I love my Spendors and will definitely not part with them.
Many thanks in advance!
vii) Other...
