Wall mounted speakers/supports for CR603
jaffers1969
6
I am planning on buying a Marantz CR603 for my kitcken/dining area since I spend an awful lot of time in there :)
Due to lack of space, the speakers will need to be wall mounted at one end of the room.
Can anyone recommend a suitable set of speakers for wall-mounting and supports for them. Ideally I'd like the speakers to be as small as possible without compromising sound.
My budget is £250 for speakers and £30 for mounts.
Zia
jaffers1969 said:
Zia
Q Acoustics do some very good speakers and have their own wall mounts as well
Brackets:
http://www.amazon.co.uk/Acoustics-2000-Series-Wall-Bracket/dp/B004VW5AX0/ref=sr_1_5?ie=UTF8&qid=1357650118&sr=8-5
Speakers: - 202i's: http://www.amazon.co.uk/ACOUSTICS-2020i-SPEAKERS-PAIR-GRAPHITE/dp/B006H4E1XU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1357650154&sr=1-1
2010i's: http://www.amazon.co.uk/Q2010I-Pair-Bookshelf-Speakers-Graphite/dp/B0063FT3WW/ref=sr_1_3?s=electronics&ie=UTF8&qid=1357650193&sr=1-3
These will work superbly with the CR603 :)
jaffers1969
6
Thanks for the suggestion :) . These were one set of speakers I had looked at. Given my budget is around £100 more though, I would also be interested in others too.
