Wall mount speaker shelves/brackets?
fayeanddavid
191
need to get the speakers of the welsh dresser (??) and onto some suitable wall mounting affair!
I have ageing Mission 771s which deserve better.............what I have seen at the cheaper end of the field re brackets and shelves seem pretty poor and quite industrial..............looking for some pointers as to what could be recommended
vanceg:
Hi
Have a look here, there's plenty of choice for your Missions: http://www.av4home.co.uk/acatalog/Speaker_Wall-Ceiling-Mounts.html?kw=loudspeaker%20bracket&fl=9096&gclid=CNG-5aa5rqECFY-X2Aod1R5X-A
According to the 77 series user manual: http://oldsite.mission-hifi.com/archive/77series/77_manual.pdf, your speakers weigh 3.8kg so you have plenty of choice
Vance
Great stuff thanks
Had a look at what's on offer, next question would be are the Universal Ball Joint type brackets as good as/better than/worse than the wall mount metal brackets where the speakers are seated on the bracket rather than hanging from it??
Please.
