R Ron Leizrowice New member Nov 26, 2013 3 0 0 Jan 9, 2014 #1 Does anyone know of any adjustable wall mounts for Concept 20s?
John Duncan Well-known member Jan 8, 2008 2,035 34 19,720 Jan 9, 2014 #2 I'm sure some could be found but they're 1) heavier than your average speaker and 2) incredibly deep - are you sure you want a speaker poking out 18 inches from a wall, which is what they're going to do?
R Ron Leizrowice New member Nov 26, 2013 3 0 0 Jan 9, 2014 #3 Well theyre on my desk at the moment so they're already sticking out by 18 inches. I just want to get them above ear level.
T The_Lhc Well-known member Oct 16, 2008 1,176 1 19,195 Jan 9, 2014 #4 Ron Leizrowice said: Well theyre on my desk at the moment so they're already sticking out by 18 inches. I just want to get them above ear level. Click to expand... Why would you want them above ear level?
R Ron Leizrowice New member Nov 26, 2013 3 0 0 Jan 9, 2014 #5 Well I mean more above ear level then angled downwards so the tweeter points at my ear drum. I wan't them higher rather than lower to save desk space.
P Pistol Pete1 New member Jan 27, 2008 248 1 0 Jan 9, 2014 #6 Would the B Tech BT77 wall bracket be of any use?
