ID. said:I try not to think of what level of kit he could have bought using the funds from all those "upgrades" that were probably just sideways moves to similar budget kit...
davedotco said:ID. said:I try not to think of what level of kit he could have bought using the funds from all those "upgrades" that were probably just sideways moves to similar budget kit...
This is not entirely a price thing, though the really good stuff is not cheap, but an ability to cut through the technical limitations that effect all hi-fi and simply get straight to the music. Just a quick example, Electrocompaniet, Sugden and Devialet do it for me but Chord, Krell and Bryston do not.
davedotco said:Covenanter said:Matthew is absolutely right in saying that it's the music that's important. I get the feeling that for many posters to this forum it's the kit that's important. I suspect that if you spend say £2k on your hifi setup (and avoid stupid mismatches) you are going to get something that is perfectly good at reproducing music. After that you can doubtless get improvements but they will cost you a lot and get you very little.
Chris
Not for me.
There is nothing that I can think of that can be bought with that budget that will do it for me, 3 or 4 times that I would say.
I think the really big step up comes in systems in the £5-10k region, personal I know, and I admit that I am no longer that conversant with that much in the way of expensive gear, but in broard terms those are the sort of figures I would be looking at should I want something new and good.
matthewpiano said:The box swapping has always largely been self funding - selling kit to buy kit.
Chris
BigH said:I have heard lots of £2-£3K systems, to me most of them had problems, many were unbalanced and unmusical, you make it sound so easy to get a good system for £2K.
So what would your recommended £2K systems be?
altruistic.lemon said:BigH said:I have heard lots of £2-£3K systems, to me most of them had problems, many were unbalanced and unmusical, you make it sound so easy to get a good system for £2K.
Sorry for the hijack, but Magnepan MG 12/NAD 356BEE/NAD CD player or Sony Blu-ray.
Covenanter said:davedotco said:Covenanter said:Matthew is absolutely right in saying that it's the music that's important. I get the feeling that for many posters to this forum it's the kit that's important. I suspect that if you spend say £2k on your hifi setup (and avoid stupid mismatches) you are going to get something that is perfectly good at reproducing music. After that you can doubtless get improvements but they will cost you a lot and get you very little.
Chris
Not for me.
We will have to agree to differ then!
Chris
davedotco said:I have no doubt that you can put together a technically very decent system in the £2-3k region and in fact £2k-ish was what I was budgeting for my playback system last year when I thought, erroniously, that I was going to be able to to buy a new setup.
BigH said:altruistic.lemon said:BigH said:I have heard lots of £2-£3K systems, to me most of them had problems, many were unbalanced and unmusical, you make it sound so easy to get a good system for £2K.
But Maggies need some space and the right size room, so maybe not suitable for many people. Also I hear they benefit from a powerful amp.
altruistic.lemon said:BigH, you asked what was a balanced, musical system, which the one I've suggested is. The 356BEE is easily powerful enough - all NAD amps can ramp up the power considerably for short bursts, it's one of their design features.
BigH said:davedotco said:I have no doubt that you can put together a technically very decent system in the £2-3k region and in fact £2k-ish was what I was budgeting for my playback system last year when I thought, erroniously, that I was going to be able to to buy a new setup.
What would you suggest for £2K?
matthewpiano said:I've got to be honest, I'm pretty disillusioned with modern, affordable hi-fi. There is always some feeling of it not quite being 'right' which I don't get with some of the vintage gear I've used - stuff like old Pioneer SA and Sansui AU amps, even the lower end stuff.
Anyone else lean towards the vintage stuff?
BigH said:Speakers have developed quite a bit over the last 20 years, just look at the new driver materials, different shape of cabinets, more active speakers available. What other parts do you mean? Amps and cd players are hardly changing.
matthewpiano said:Well, it isn't in direct contradiction to the amount of times I've swapped my kit. I do find a lot of the kit impressive initially, but over longer listening sessions the weaknesses only become more apparent. I'm not saying its rubbish now - only that it doesn't satisfy me musically over a longer period of time.
chebby said:matthewpiano said:Well, it isn't in direct contradiction to the amount of times I've swapped my kit. I do find a lot of the kit impressive initially, but over longer listening sessions the weaknesses only become more apparent. I'm not saying its rubbish now - only that it doesn't satisfy me musically over a longer period of time.
I doubt anything ever will. Whatever your budget. You are just unfortunate in that way.
BigH said:Covenanter said:Matthew is absolutely right in saying that it's the music that's important. I get the feeling that for many posters to this forum it's the kit that's important. I suspect that if you spend say £2k on your hifi setup (and avoid stupid mismatches) you are going to get something that is perfectly good at reproducing music. After that you can doubtless get improvements but they will cost you a lot and get you very little.
Chris
altruistic.lemon said:DDC, you do go on about nothing sometimes! The problem is assuming that anything other than speakers is going to make a big difference, and unfortunately matthewpiano has apparently putting his money into budget sources and amp which means he has not been able to buy good quality speakers.
Had he bought something like Neats, the Sonus Fabers or whatever and coupled them with an appropriately powerful but budet amp, this thread would not have existed. Really, put the money into the bits that make the sound, that's where it is, the amps have little to do with it as long as they are in spec.
