Hi All
Van Den Hull Phono Leads D-102 Mk 111 Connected Between Linn Pre And Power Amp. Also From Linto MC Amp To Pre
Amp. One End Of These Cables Has Got "Ground End" So All Connections Are From The Source. Van Den Hul Thinks It
Might Be Better With "Ground End" From The Power Amp. Is This A Balanced Or Unbalanced Theory? System Has A Bright
Sound With Low Bass, No Problem To Reverse The Leads, But Would Like A Bit Of Info.Any Suggestions Wecome
System. Linn LP12 1983 Upgraded High End. Kairn Phono Pre Amp Linto MC Amp With Klout, Kaber Speakers
Meridan 200 Black Box 606
