The black and blue are the same but the black outer jacket is thicker as its designed to be used on tour. The blue is for studio and home applications. The clear is 'hi-fi' cable. I have blue and clear at home as they are good quality copper and cheap. The blue is easy to work with, the clear is shotgun style cable and not easy to route as it only bends one way. In terms of audible differences between black/blue and hifi...there is a review somewhere online that claims there is a difference. However, everyone else I know who has used both claims there is no difference. I would buy the blue. 👍
Is this the review ?
Van Damme “Blue” and Hi-Fi Grade 6.0mm Speaker Cables | Hifi Pig
www.hifipig.com
Cheers for that!
If that's anything to go by, the hifi ones may not be right for me as they tend to focus on "more" bass if that review's anything to go by.
With a good recording I absolutely love my system but very low / bassy songs it can be a bit too much and become a bit muddy / dull.
So if i swapped my 3M long QED 79 strand speaker cable for bell wire, with its higher resistance, there would be no sound quality difference ?For the length required for hifi typically 2 to 3m per stereo channel there would be no resistance difference that would affect sound quality. They will sound the same. Colour preference will be your choice. VD blue is a good cable, as good as any for sound quality. Enjoy.
Can i ask what cables you currently use ?
The blue / black versions just seem to be the same as the QED 79 strand i use but with a thicker "jacket" to prevent damage if stepped on in a studio, on stage etc.
I honestly doubt that the "HI-FI" version would differ greatly, sound quality wise, but it has more strands of copper, therefore, a lower resistance than the other models so i maybe wrong...
QED 79 strand is available in black or white and would be more flexible (i guess) than the Van Damme offerings if that is a consideration.I currently use this as I had some spare from another room
The white really stands out like a sore thumb in the main room though so wanted to change it and whilst I was doing so would probably go to 4mm as opposed to 2.5mm as one of the runs is a "reasonable" length.
...yet. 🙂
- #9 and still no anti cables don't make any difference brigade .
I am happy with all of my VD cables be they speaker or RCA cables.Dont assume I am anti. Don't think I said anything about bell wire did I. The diameter of bell wire is not sufficient. Proper guage and OFC will do the job. VD is used in recording studios and for good reason, it does the job perfectly. Upto you what you want to spend on cables.
Did I say anthything about bell wire? No. Do a loop impedance test on each cable VD and QED let me know the huge difference you see on a 3m run of cable. If you do the cable is either faulty or has badly designed geometry of the strands.So if i swapped my 3M long QED 79 strand speaker cable for bell wire, with its higher resistance, there would be no sound quality difference ?
Good quality for reasonable outlay. Enjoy.I am happy with all of my VD cables be they speaker or RCA cables.
My speaker cables are the 6mm ones and not that cheap.But worth it and they look nice.Good quality for reasonable outlay. Enjoy.
That's the one. I have the blue for my surround setup. Longest cable is 11 metres. For rear right speaker. I find the 2.5mm is more than sufficient at that length. Being so flexible is bend around corners easily which is why installers use it a lot. Fisual also do a similar cable. Either one is good enough - no need to spend more.Is this the review ?
www.hifipig.com
Doh, just spotted you mentioned the Fisual! What's a reasonable length?I currently use this as I had some spare from another room
My cables are white, a nice neutral colour. They sound fine.I feel a bit relieved that my speaker cables are clear.
If someone were to do the swap without your knowledge.....So if i swapped my 3M long QED 79 strand speaker cable for bell wire, with its higher resistance, there would be no sound quality difference ?
My 6mm look thicker and wider than your 4's but I know how to waste money big timeI’ve posted this before, but this is what Van Damme 4mm Hifi cable (plus links) looks like on my ATCs.
These were custom made by this chap…
https://www.lucasoundvision.com/
Chord Cables – Qed audio Cables – Van Damme Cables – Speaker Jumper Cables – Subwoofer Cables – Wireworld Cables – best speaker cable terminationwww.lucasoundvision.com
At the time I bought them, he was in the UK, but during COVID I think he returned home. Still very competitive pricing though.
View: https://imgur.com/kJSlW28
