floyd droid said:Macspur said:As for low power, my Sugden only runs at about 30 watts and is quite sufficient for the SHL5's.
Mac
Yep I knew that Mac. 🙂.
Guessed you did. What kit do you have Floyd?
Mac
Mac
floyd droid said:Oooh now that would be telling wouldnt it, hence i have no sig. But (note no brand names,lol). I run a 300B single ender and a pair of 845 monos. Depending on what mood im in kinda makes my mind up which one/ones i plumb into the gas. Speaker wise, ART Moderne 10s, ive mentioned these before on here so no point not disclosing that innit.
Likes to keep em guessing i does. 😉
Macspur said:O my word... thought this listening to HiFi was supposed to be a relaxing passtime! LOL!
Might be more straightforward with cat litter? I think that's what you said as an alternitive?
Mac
CnoEvil said:EDIT. Just found this....looks like rice could be the way to go (the test was conducted on the HL5): http://www.diyaudio.com/forums/multi-way/152592-alternate-speaker-stand-damping-material.html
floyd droid said:CnoEvil said:EDIT. Just found this....looks like rice could be the way to go (the test was conducted on the HL5): http://www.diyaudio.com/forums/multi-way/152592-alternate-speaker-stand-damping-material.html
The third post is class , straight out of my top drawer. Brilliant :rofl:
CnoEvil said:Macspur said:O my word... thought this listening to HiFi was supposed to be a relaxing passtime! LOL!
Mac
Who said anything about relaxing!!
If this sorts the problem, it will be a cheap fix....also try the heavy tiles under the stands.
If you go the cat litter route, get as fine a stuff as possible. As far as I know, Inter_Voice uses it on here (I have no experience of it, but it should be a good damping material).
Macspur said:Excellent! my wife's Asian, so we've always got plenty of rice about... will give it a whirl.
Need to buy some of those granite boards, the tiles are too small.
Mac
CnoEvil said:Macspur said:Excellent! my wife's Asian, so we've always got plenty of rice about... will give it a whirl.
Mac
I hope your wife is long suffering - I'm trying to picture her expression as you say you are going to fill your stands full of rice!!.....actually, come to think of it, I know that expression only too well!
Just have to pick my moment.... bless her, only last night, she asked when will all this be over... didn't have the heart to tell her it never does.
The granite boards are 30cm x 40 cm......is that big enough?
Not sure, have to check before buying.
Mac
Macspur said:Sounds similar to Paul's from Jordan's equipment...
Remembered the other Mastersound he mentioned, the DueTrenta... any views?
Mac
