1) The front left and right preouts of the A/V Receiver go to an input on the stereo amp (Tape 2 for example)
2) Some stereo amps (not many) have a fixed-level input especially for this purpose so you can miss this step out: otherwise set the volume of your stereo amp to about 10 o’clock and run your speaker calibration routine on the receiver. Then always use this volume setting on the stereo amp whenever you watch AV - overall volume is handled by the receiver.
3) When watching AV, have both amps on - the stereo amp will handle the front speakers, the AV amp will handle the rest.
4) When listening to music, the AV amp is out of the equation so won;t degrade the sound.
Hi all, just to clarify will the above mentioned procedure work with any stereo amp and AV amp (with preouts)
Is there much difference in the Arcam A80 & A85, many thanks in advance to all who reply.
