The usual wav 16bit 44.1kHz 1411kbps is the same standard as CD but files can be converted to wav in 16bit 24bit or 32bit with sampling rates of up to the full 384kHz. I use AIMP media player's audio format converter to upscale my compressed lossy mp3 files to WAV 32bit float 192kHz sampling. The bit rate of the files is then an enormous 12288kbps. A 5min tracks uses about half a gig / 500mb. It is important to change the media player settings to output at 32bit float 192kHz to match the input and the outboard DAC must be able to handle 32bit 192kHz. The default setting is usually 44.1/16bit and leaving at that setting will cause all benefits to be lost. The sound is amazingly good and the reduced quality of the 320kbps mp3 is restored to studio quality or better. VU meter movement is greatly increased, demonstarting much increased dynamic range. The noise floor falls to well below audability. This allows the full decay of sound to be heard - no chopping off or distortion. Left and right of the stereo image is absolutely clearly defined. This conversion runs rings around lossless but compressed 24bit 192 flac. With wav 32bit float 192kHz there is greatly improved depth, detail, precision, imaging, clarity, bass is restored to a strong deep reasonant punch instead of being wooly. Treble is clear crystaline, extended detailed with slow natural decay instead of being slightly coarse, grainy and splattery with compressed mp3. The upscale creates a wide reaching soundscape drawing me into the music - I pick out nuanses and hear thing never before heard. The clean ness of the sound outclasses anything heard before. The benefits are even there from 128kbps mp3s with the upscaled sound coming close to studio master quality. This upscaling happened with me playing with settings to find out just how big such a file would be. I wasn't listening out for sound improvement, or expecting it but immediately on playback my head and ears pricked up in disbelief of what I was hearing. There will be plenty of people who will say or think I am talking rubbish and say compressed lossy sound cannot be restored. I say to them if you dont believe me try it. It costs nothing to do. So do it and hear the results for yourself. Just follow what I have written and to save complications use the same media player I use. It is freeware. Uninstal afterwards if you want to. There is absolutely no doubt in my mind that the downgrading of sound quality in compressed mp3 and other compressed formats is restored to the best possible and probably absolutely restored to studio quality just by converting up to this huge 32bit/192kHz wav. My DAC can only do 32bit via USB. Coaxial and optical is limited to 24bit. I do not know if this is universal across all DACs or not.
