jaccoet said:
I am just delving into the world of audio and of all the threads and reviews read so far this has by far been the best read. I do have a limited budget and cant push beyond £150. Primary use will be for PC gaming and music.
I am looking to put this setup together shortly and just had a few additional questions.
Do I require additional cables to connect speakers to the UCA202 and if so what type is recommended. There is also a comment that the volume control is rear mounted? However reviewer says there is a tool to control from the front. Is this correct?
I have also read this thread on recommendation - http://www.cnet.com/uk/news/build-your-own-desktop-stereo-for-under-70/ is it better to get the Lepai Amp rather the than the UCA202.
Any advice is appreciated.
Given the budget, the UCA202 is a 'no brainer', it connects to your computer via a captive usb, and has phono sockets out.
The Seiwin speakers mentioned above are pretty obvious solutions at this price too, Studiospares sell the SN4a from one range, ideal for the desktop or the rather prosaic looking but excellent S5a and S6a from another, (All built by Seiwin)
The 5a and 6a are really a bit too big for a desktop, stand mount them and they are outstanding as regular hi-fi and ridiculously cheap.
Depends on your budget and choice of mounting and positioning.
In all cases these speakers have balanced inputs on XLR and three pole quarter inch jacks, easiest connection is regular phono cables of the required length and simple phono to two pole jack adapters, they will unbalance the inputs to suit.
They also have level controls that are rear mounted, you should set up the system with these controls on minimum, play some music with the volume in your software player on maximum. Raise the volume on the speakers to the loudest volume you would normally use and leave them there, use the volume in your software player for normal use.
The cheapest, the SN4a option is around the £150, the most expensive S6a, less than £200 including dac. Just buy the best you can afford bearing in mind the mounting requirements mentioned above.
