I have just purchased some Dali Opticon 6 MK2 speakers and am looking to upgrade my Arcam A19 amplifier. I am considering the Cambridge AX81, but could I just add an external DAC instead?
Hi. You're considering a DAC in addition to the A19 vs the CA with it's integrated DAC?I have just purchased some Dali Opticon 6 MK2 speakers and am looking to upgrade my Arcam A19 amplifier. I am considering the Cambridge AX81, but could I just add an external DAC instead?
yes, your A19 is a good amp. Integrated dacs in modern amps are good but obviously not upgradable.I have just purchased some Dali Opticon 6 MK2 speakers and am looking to upgrade my Arcam A19 amplifier. I am considering the Cambridge AX81, but could I just add an external DAC instead?
Source is a Project Carbon turntable and Cambridge CXN (V1)Hi. You're considering a DAC in addition to the A19 vs the CA with it's integrated DAC?
Also, what's your source?
I don't know too much about add on DACs. What would you recommend?If you're happy with how it all sounds now just add a dac. If you need something different consider a replacement
I think the DAC in the CXN should be fine for your system. But if you want to try one, get a new Cambridge DAC Magic 200M on home trial from Richer Sounds. It would make sense in the context of your system.Source is a Project Carbon turntable and Cambridge CXN (V1)
I also think an amp upgrade would be beneficial, and the CXA81 is not it, imo, just a sideways move. I'd also audition Naim's Nait XS3 and Musical Fidelity M5si. The CXN has a decent dac, imo, and only a similar expenditure would be a real upgrade, and atm I think an amp brings more to the table.My instinct would be to go for a Arcam A39, as mentioned by @nopiano . It's an excellent amp and will be a very decent upgrade to the A19. And the added bonus is its phono stage. It doesn't have a Dac built-in so you'll need to budget for something like a Arcam iirDac.
In terms of synergy, my hunch is It's a better match than the Cambridge.
Alternatively, I'd also look at a Creek Evo 100A, but you'll have to factor in a phono stage and Dac.
Firstly I'm not sure exactly vwhat you want it for, but this unit (which I haven't heard but is getting rave reviews around the net) covers a multitude of bases at not silly moneyI don't know too much about add on DACs. What would you recommend?
Also, I think the A19 is a great amp at it's price level.
Agreed: if it wasn't for the Leema I would have the A39 at the top of my short list.It's already been said above, but to echo...
Forget about a DAC your CXN is great in its own right. If you like the A19 go up the range.
I've previously owned the A29, A39 and a CXN.
Skip on past the A29, they are prone to issues with the rails. The A39, for the money is a beast of an amp and is an almighty jump up from what you've got at the moment. I loved mine and it saw off plenty of competition...
Expect to pay in the region of £550-£650 for a good example. Also, if you pick one up, ask the seller if they have proof of purchase or warranty details - the FMJ's have a 5 year no quibble transferable warranty which you can take advantage of.
Never heard a Dali that wasn't smooth, but also like Arcam and Creek ( Evo 2 and Destiny, don't care much for the Evo 50, though, sounded a bit gutless to me, haven't heard the 100).I think the Naim XS3 would be a step too far. Heard earlier Naim XSs and they require smooth speakers to hear them without the eardrums exploding.
IMO Arcam and Creek are the best match for Dalis on a budget.
Fair play.Never heard a Dali that wasn't smooth, but also like Arcam and Creek ( Evo 2 and Destiny, don't care much for the Evo 50, though, sounded a bit gutless to me, haven't heard the 100).
Yeah, sorry about my lazy wording there, what I meant was that I was also a fan of the Arcam suggestion. But having Naim on the list is never a bad thing, imo.Fair play.
Do you remember JoelSim? He had a Arcam A85 with a P85 powering his Ikon 6 and loved it. Currently @Blacksabbath25 has a Yammy powering his Rubicon 8. Although not a bright speaker Dali seem to prefer a more considered presentation.
Hahaha, you're right, but at the same time, the only clear idea that can come out of this is that everyone's hearing and preferences are different, and auditioning yourself is the only way to know.To the OP, if you thought you'd come out of this with a clear idea ... 😁
Can you explain what you mean by dull? Cambridge are generally livelier than the brands I've mentioned. One thing the Cambridge shouldn't be is dull.I would not put a Cambridge amp with Dali speakers i had a demo on a Cambridge flagship Pre - and power amp and i felt it sounded dull .
Do not get me wrong the Cambridge amps are capable but just not on a sonic level and not to get the very best out of the Dali opticons .
Amps you want to look at are Yamaha , Arcam A39 upwards , Hegel , Luxman if you get the combination right you will no .
You rascal.To the OP, if you thought you'd come out of this with a clear idea ... 😁
