Upgraded to Audirvana Studio - Audio-fooled NOT
NHL99
41
8
545
What a difference! Have a license for the Audirvana, doesn't sound anything special. Downloaded the free 30-day trial of Audirvana Studio. So much better audio wise. Using Campfire Audio to MacBook Pro. Anyone else hear the difference?
Tinman1952
1,290
734
2,070
Interesting…. I bought a life time license some time ago and was not going to pay on a monthly subscription model too. I wonder what the improvement actually relates to…?
Tinman1952
1,290
734
2,070
Does Audirvana give you bit-perfect playback? If it does, then it is doing the same as Foobar2000 with ASIO or WASAPI drivers enabled.
Well actually Audirvana does a lot more than just bit perfect playback.
It optimises the entire operating system for audio playback and disables non essential services. Plays from RAM too. 🙂
NHL99
41
8
545
Have to add that the listening experience is with in-ears connected to the laptop directly. Also tried the Audirvana Studio with USB to a somewhat outdated DAC, where the benefits disappear. It's all in the details of the particular setup. The chain isn't stronger than the weakest link.
Friesiansam
What exactly does that add though? Surely bit-perfect is as good as it gets, the ones and zeros delivered to your DAC entirely unadulterated.
NHL99
41
8
545
From their website
'Audirvāna loads, decodes and processes the entire audio data of a track prior to playback in a buffer memory.
This limits processor activity during playback and protects the music from playback jitter and possible signal interference by stabilizing the computer power supply and limiting processor activity to the bare minimum: minus 0.5% CPU load less than 0:5% of CPU load.
In addition, Audirvāna delivers a ‘ready-to-play’ digital audio stream that allows your converter to operate under optimal conditions, i.e. a PCM (or DSD) stream already decoded, which takes into account the characteristics of your DAC – for the order of reception of data beyond 16bits for example – and reduces the tasks to be performed at its level. With quality as sole priority, Audirvāna does not have to seek a compromise between processing speed and accuracy and can thus mobilize the computer’s computing power using the best algorithms.
Today, most DACs operate at very high internal frequencies and low resolution. This conversion involves oversampling. Benefiting from the processing power of your computer, much higher than the internal capacity of the DAC, Audirvāna can run more sophisticated and demanding oversampling algorithms, and feed your DAC with a signal containing more accurate data that facilitates the interpolation work.'
Reactions: Tinman1952
Friesiansam
Well with an AMD Ryzen 7 2700 8 core 16 thread CPU, processor load is a non issue, as is jitter as it's taken care of by my DAC/headphone amp. Variations in CPU load during playback will be beyond Audirvana's control as they will be caused by the operating system and other software. Stability of pawer supply is ensured by buying a good quality PSU for your PC, which I did when I built my PC.
The rest of the quote has a feel of the same kind of, blind the customer with pseudoscience waffle, that high-end cable manufacturers use. I did however try running the free trial, except Audirvana refused to allow me to add my music to it's library. The instructions online state that one should click the "add a folder" button under "local", there was no such button and I am really not bothered enough to do anything about it. Foobar2000 just works and works well.
NHL99
41
8
545
What definitely could affect the sound is the filtering done with oversampling
'You can oversample your audio files directly in Audirvāna before playback on your system, using one of the two built-in high-performance algorithms: SOX (SoundExchange) and R8 Brain. This can improve sound quality, sometimes quite noticeably, depending on your system’s converter and the settings you choose.
Indeed, almost all DACs today on the market operate on a very-high-frequency switching-principle with a resolution of only a few bits. They therefore systematically oversample the signal just before the actual conversion, but work with limited computing power and more or less powerful algorithms, particularly for chip-cost and latency reasons.
You can use Audirvāna to carry out this operation upstream: it will benefit from the computer’s much greater computing power, and with a high-performance algorithm. This will facilitate the DAC’s work by giving it a stream that contains more precise points at the base.
The settings associated with each algorithm are slightly different, but both will allow you to define the multiple of the sampling rate to be applied (x2, x4 etc.) as well as to fine-tune various filters, essentially to neutralize the artifacts that result from these operations.'
Tinman1952
1,290
734
2,070
Why is it not?
Because it isn’t.
I’ve had this discussion before with members of the ‘digital is just ones and zeros’ or ‘measurements are everything‘ brigade.
If you don‘t accept that a computer is the worst place for digital audio because of contaminated power supplies and electro magnetic interference….and believe ‘bits are just bits’ then nothing I say can persuade you differently.
You can take the Audirvana challenge and try it yourself for free…..
I did and decided it was worth paying for as it improved sound quality.
Even getting it to convert FLAC files to WAV before sending to my streamer brought about an improvement.
Tinman1952
1,290
734
2,070
Well that says it all………🙄
Friesiansam
One thing a computer is designed to do above all else, because otherwise it simply would not work, is work with ones and zeros without them becoming corrupted.
Tinman1952
1,290
734
2,070
So you don’t understand the difference between transferring a digital file (i.e. A picture) and playing digital audio…..
Friesiansam
What you mean is…”I didn’t actually try the software because I couldn‘t see how to add my music library…and gave up.”
I really don't care what you think but, I followed the instructions provided on the website. I do not pay £64.99 per year for software when it doesn't work properly and, when free software works and, works well.
Don't expect any further responses, I'm done with this and, done with this website. Too many idiots who stoop to insults when they don't get agreement.
Tinman1952
1,290
734
2,070
Shame you (rather immaturely) feel ‘insulted’ when someone expresses a different opinion. I had no trouble with the Audirvana software…but you were ‘not bothered enough’ to implement it.
This forum is about the exchange of information, experiences and knowledge. If you find that uncomfortable then that’s unfortunate.
Office Dog
22
525
Reading this thread back, Tinman1952, I suspect that it's not the fact that you are expressing a different opinion. It's your tone when you do it.
'Say what you mean, but don't say it mean.'
Tinman1952
1,290
734
2,070
Sorry I have to disagree. Nothing wrong with my tone….remember it wasn’t ME who called the other ‘idiot’…..
ASK THE COMMUNITY
