Upgrade to rotel rc 1550 from 04se, worth it?
Bebeboy
13
My current system:
rotel ra04se as preamp
rotel rb1080 as power amp
denon dcd 1650 cd player
b&w 684
monitor audio br6
i intend to buy a rotel rc 1550 preamp. Is it worth upgrading from 04se as preamp or the difference would be minimal.
any input mates?
ISAC69
73
You have a good power amp I don't think that changing your pre will improve the sound much . Why do you want to to upgrade the pre ?
Bebeboy
13
I thought upgrading to rc1550 would benefit me as i expect the sound quality will be better.
ISAC69
73
I don't think that you will notice any difference but if you want to be sure It is better to make a demo .
cheyworth
145
Changing from using in integrated amp to a pre should give some improvement in sound, but as said a demo is a must as only you will know if it's worth the cost. of course the adition of a remote may make the cost worth it?
Bebeboy
13
The upgrade would cost me roughly £160. Well it must improve the sound. I am really confused.
Bebeboy
13
Bebeboy said:
My current system:
b&w 684
monitor audio br6
any input mates?
i believe a dedicated preamp is better than an integrated being used as a preamp.
ISAC69
73
The power amp has much more influence than the pre on the sound unless you are buying an expensive high end pre I realy don't think that
the sound will be improve but you will benefit a remote control , it is frustrating to operate Hi Fi system without it .
Bebeboy
13
Thanks mate, i think i would have to consider getting the rc1550
MUSICRAFT
Hi Bebeboy
The RB-1080 is an excellent power amplifier. If you are willing to look at used/ discontinued pre amplifiers then a NAD C160 or a Rotel RC-995 are also worth bearing in mind as the C160 and the RC-995 pair well an RB-1080.
All the best
Rick @ Musicraft
Bebeboy
13
Thanks rick, bought the rcd 06SE and rc 1550 already. What a great sounding preamp. Perfectly matches my rb1080. :)
Bebeboy
13
ISAC69 said:
An excellent choice . Enjoy !
Thanks mate. On the contrary my all rotel set up, (cdp, pre, power) matches perfectly with Monitor Audio BR6 than B&W684. :)
