upgrade rotel ra 06
Hi
I have the rotel RA 06 amp + B&W CM 7.
I am very pleased with the sound!
Yet, I would like to upgrade the amp. What are the possibilities?
Can I use the RA 06 as a preampliflier?
What is the best solution.
I am new in this area so thanks for response.
Jan
If you like the sound, get a Rotel RB-06 to biamp the CM7s.
I used to have the Rotel RA03 and added a Netaudio upgraded Quad 405 MK3 DMPSU and simply used the Rotel as a pre. Worked very well and cost me £500 in total. Just one option of many!
Thanks for responding.
Although RB 06 is still on the site of Rotel, it is not for sale anymore in Belgium.
I am thinking to use the RA 06 as a pre and get the RB-1582 as an endamp.
Would this work?
Yes, you can use the RA06 as a pre and the RB-1582 as power. I would look to finding a better pre in the near future though because I found the RA03 (same as RA06 pretty much) to be a bit rubbish in these duties.
