- Aug 10, 2019
- 2,556
- 5
- 0
Hi all!
I am considering upgrade from Cambridge Audio 340A amp to 550A/650A, so I would like to here your opinion is this upgrade worthwhile?
My current setup is:
- Amp: CA 340A
- CDP: CA 340C (to be second step in my upgrade quest, or maybe replaced by DacMagic in combination with WD TV Live)
- HC: Yamaha RX-V765, fronts pre-outed to CA 340A
- Speakers: front CA S70, rear S30, center S50
Looking in the specs, it seems that main difference between 550A and 650A is power, however It might be maybe wise to go for 650A due to fact that I will use it as fronts amp in HC.
Thanks a lot for your input!
Regards,
B
- Amp: CA 340A
Regards,
B
