Universal remote
Thorseng
12
Hi everyone,
I own the hifi system consisting of the Densen B310 and B200. Unfortunately, it didn’t come with a remote control when I bought it. The "Gizmo" remote, which is the original one, is impossible to find and is no longer available for purchase.
Does anyone have suggestions for a universal remote control for my system?
BR
Hi everyone,
BR
P
actually I’ve already got that remote. It doesn’t work and i believe that it is a scam…
I got a spare for my MF gear from here:
Alas Densen isn't listed but as a small manufacturer, I very much doubt they make their own transports (including the IR circuitry). Densen ought to be able to tell you which manufacturer, and if they can give you a compatible model number from their range, that should work.
Sorry, not as straightforward as you might hope.
Reactions: Thorseng
Worth checking WHF old thread.
Ouch just look at the cost :screamcat:, check link below
This might work and it's cheap.
Reactions: Thorseng
