Universal Remote - IR and Bluetooth
Juzzie Wuzzie
550
339
19,270
Has anyone discovered a candy-bar remote control that incorporates the ability to control units via IR and Bluetooth? For instance, to control a "classic" amplifier and a streamer that would use a Bluetooth remote? Alternatively, to control a television and a Firestick (noting that is achievable via HDMI-CEC control)?
Thanks in advance.
I have a Logitech Harmony remote that can do that.
Have a quick glance at Amazon.
You can set the filter to only show Bluetooth or Infrared remotes.
All various from relatively cheap to darned expensive!
Reactions: Juzzie Wuzzie
Universal remotes are pretty limited these days (Everyone uses an app instead) since Logitech left the market.
Does your phone have a infrared sender built in, as if so you can get an app to use it as a IR remote.
Bill
Don't think I want to use a phone. Had two Logitech remotes (550 and 650) but they are no longer fit for purpose.
I'm trying to get a single remote to handle:
1. Firestick (BT) into Samsung TV (IR) with Sonos (HDMI-CEC controlled) for television
2. WiiM (BT) into PrimaLuna (IR) for music
In a perfect world, it would also handle:
3. Firestick (BT) into Epson Projector (IR) with Sonos (HDMI-CEC controlled) for movies
