Universal remote.................but which one?
fayeanddavid
191
OK, so now we have a remote for each of the following;
Yamaha amp
Sony tv
Denon dvd player
Sony BDP
Sky HD
which I think is a bit of an overkill!!!
Also complaints form OH (do we need all of these etc etc)
So, what is out there and what is good, bearing in mind that I am a complete technophobe...............so programming must be simples?
They're all good. You just have to connect to the Logitech site and download the codes. Check before you buy, though, to make sure you each of your devices is supported.
I have the basic Harmony 300 but you'd need a model up from this since it only works with 4 devices.
Sorreltiger
42
I have sung the praises of my Harmony One on here many times. It has been the key to making the whole HT experience enjoyable for the WHOLE family (thereby making it much easier to justify more expensive purchases!!!)
professorhat
992
22
18,895
The 555 works for me - can be picked up occasionally much cheaper than the One so worth a look - you miss out on colour screen (do you need a colour screen on a remote control?) and rechargeable battery, but you could always use rechargeable AAAs instead - I just use regular ones and they last a good few months. It also has the four coloured buttons in physical form rather than having to use up buttons on the screen for them which could be important if you have a device which uses them extensively.
Crossie
58
Logitech Harmony 555 will do all you want and more - up to 15 devices. Logitech customer support is superb. Works for me
fayeanddavid
191
Crossie:
Thanks again for the info
