manicm said:One to get the feathers flying and test tubes thrown again.
http://andreweverard.com/2015/06/08/high-resolution-audio-now-with-added...
Covenanter said:manicm said:One to get the feathers flying and test tubes thrown again.
I'm not sure it will! All Andrew is saying is that you need good cables to make a network operate well enough to carry high resolution music. If I had such a network I would do the same.
Chris
manicm said:Covenanter said:manicm said:One to get the feathers flying and test tubes thrown again.
Chris
Yes but the bit perfect brigade will cut you down.
andyjm said:Read the article. No axe to grind with Andrew, who by all accounts a decent chap, but he really should stay away from commenting on digital systems - or at least check with someone who knows about them first.
Ethernet / Cat5e is spec'd at 125Mb/s on a 100M cable run. Stereo 24/192 is 9.2Mb/s.
There is some overhead with flow control and error correction, but a properly connected ethernet system has 10 times the capacity of the highest of the high resolution. That is not to say in Andrew's specific case that something is adrift. Perhaps he doesn't know what he is doing, has put the plugs on squiff, or has dodgy equipment - the point is ethernet has more than enough capacity to connect up a streamer.
andyjm said:As for using fibre for isolation, the ethernet standard is isolated/differential. Remarkably, in that little ethernet socket are tiny transformers that isolate the ethernet connection from the network circuitry. So changing the equipment may have made a difference, but whatever Andrew was doing, it had nothing to do with isolation.
andyjm said:changing the equipment may have made a difference
Covenanter said:All Andrew is saying is that you need good cables to make a network operate well enough to carry high resolution music.
tinkywinkydipsylalapo said:'Read the article'? Perhaps you should do just that, since as far I can see nowhere in that article does he suggest copper cable Ethernet isn't fast enough, or that adding the fibre optic cables speeds things up.
tinkywinkydipsylalapo said:What he appears to be suggesting, again if you do that reading thing that seems to elude you, is that the optical connection breaks any electrical connection between the components, which can surely have the effect of breaking ground planes, avoiding any route by which electrical noise may travel from one component to another.
tinkywinkydipsylalapo said:But good on you for assuming he's a nice chap but an incompetent buffoon, because of course whatever he did couldn't make any difference, even though
Why don't you try explaining why there may have been a difference, then, rather than adopting the usual 'digits is digits' stance that 'anyone who disagrees with me is an idiot'?
As you said, 'Read the article'.
cheeseboy said:...I really wish hifi peeps would stop trying to shoehorn thier ideas into the computer realm, because quite frankly it's getting more and more emabarassing.
andyjm said:the most likely explanation is that there was no change to the audio output and expectation bias came into play.
cheeseboy said:Andy has already said, using fibre would have made absolutely no difference, especially on a 3m run.
cheeseboy said:I really wish hifi peeps would stop trying to shoehorn thier ideas into the computer realm, because quite frankly it's getting more and more emabarassing.
tinkywinkydipsylalapo said:andyjm said:the most likely explanation is that there was no change to the audio output and expectation bias came into play.
As you were clearly there, what's it like in his house? Please answer on one side of the paper only, avoiding all the usual pseudoscientific objectivist clichés.
tinkywinkydipsylalapo said:I really wish those upon whom the red mist of objectivist fury has descended would stop trying to shoehorn their ideas into a criticism of something they have clearly not bothered reading, because quite frankly their imposition of what they think it says onto what it actually says is getting more and more embarassing.
tinkywinkydipsylalapo said:Or is it a case of 'reading won't make any difference so I'm not even going to try it'?
tinkywinkydipsylalapo said:Bias and placebo, placebo and bias – sorry, but you failed on the 'Please answer on one side of the paper only, avoiding all the usual pseudoscientific objectivist clichés'
tinkywinkydipsylalapo said:Remember when people had and were allowed to express opinions, rather than parroting the same old objectivist 'everyone is corrupt (oh, and stupid) except me' cant?
cheeseboy said:it's literally just one person swapping wifi for cables then declaring how much better it is
cheeseboy said:Lets take a prime example so I can demonstrate what I mean - Andrew says "It’s hardly surprising given the length of cable run involved" - "So how far did I need to cover with this latest upgrade? Ummm, two metres would have done it, but I went for a 3m"
No, what is surprising that anybody would think that optical is needed for such a small run. Optical cables for networking are used for when the distances for cat 5/(e)/6 are too great. Given cat 5e (which is enough for gigabit) has a length of up to 100m, it goes to show just how misinformed those quotes I have given above are. Back in the day optical was used instead of ethernet as it also allowed greater tranmission speed, but nowadays, it's not necessarily the case.
cheeseboy said:Again, I hope you see the irony, neigh hypocrisy of that post. If you're allowed to have and express an opinion, then so am I no?
tinkywinkydipsylalapo said:cheeseboy said:Again, I hope you see the irony, neigh hypocrisy of that post. If you're allowed to have and express an opinion, then so am I no?
Ah, but the difference is I express an opinion as an opinion, while you present yours as fact, backed up with the Sword of Justice and Misunderstanding.
cheeseboy said:Please point out which opinion I have stated as fact? Where ever possible I will back up with evidence.
cheeseboy said:No, what is surprising that anybody would think that optical is needed for such a small run. Optical cables for networking are used for when the distances for cat 5/(e)/6 are too great. Given cat 5e (which is enough for gigabit) has a length of up to 100m, it goes to show just how misinformed those quotes I have given above are.
cheeseboy said:given that he then converts optical from and back to ethernet, thus not actually changing anything
cheeseboy said:a telltale sign of somebody just playing around and not really fully understanding what and why they are doing something.
tinkywinkydipsylalapo said:cheeseboy said:Please point out which opinion I have stated as fact? Where ever possible I will back up with evidence.
OK let's try
or
or
tinkywinkydipsylalapo said:At which point I'm out of here.
tinkywinkydipsylalapo said:You're clearly showing about as much ability to read my posts as you have to read the article under discussion,
tinkywinkydipsylalapo said:and as always in these arguments the old rule of 'I don't need to try it as I know it won't make any difference' is to the fore, rendering all discussion pointless.
tinkywinkydipsylalapo said:That, along with some ludicrous, pompous and high-falutin' idea that we're having a 'debate', when it's really just a bunch of old gits throwing cobblers back and forth on something that really matters for nothing in the great scheme of things, is what's taking all the fun out of this hobby these days.
spiny norman said:cheeseboy said:tinkywinkydipsylalapo said:That, along with some ludicrous, pompous and high-falutin' idea that we're having a 'debate', when it's really just a bunch of old gits throwing cobblers back and forth on something that really matters for nothing in the great scheme of things, is what's taking all the fun out of this hobby these days.
So now you've resulted to obiligtory ad hominum attacks. Oh well.
I rest my case.
chebby said:Some pretty strenuous defence of Andrew going on back there Tinky.
spiny norman said:chebby said:Some pretty strenuous defence of Andrew going on back there Tinky.
Again, if you read my comments I'm not actually defending the guy at all, but rather berating those who don't actually bother reading something properly before launching an attack based on what they think it's going to say because all these things say the same things.
I know nor care whether what Everard does to his system makes it project holographic images across the room or bring the stars down from the sky, and in fact I find myself disagreeing with his views on most equipment he's reviewed and I've heard, and if someone hadn't started this thread I probably wouldn't even have noticed the article the thread purports to 'discuss'.
But I will defend the right of anyone to give an opinion without being slated by those too lazy to make the effort to understand what's being said before launching their predictable attacks.
This time I really am out: got a very interesting wall to stare at. ;-)
