Hi All,
This is my firstmessage to a forum such as this, so please excuse any variation to acceptedetiquette!
I am intregued to hearyour advice for a problem I face that is similar to one posed by dmkt in early 2008.
I have a newroom that has been completed as a sitting room / home theatre combination. Theroom has a fireplace, above which has been sited a plasma screen, however tothe immediate left of the fireplace is a walkway through to another part of theL shaped room therefore it has proved impossible to site the projector screento lower in front of the plasma or on the same wall. We have been forced tosite the screen to lower from within a ceiling void on the wall at 90degrees tothe left of the plasma. The projector screen lowers infront of a shutteredwindow (this feature making it impossible to site the plasma on this wall. Itherefore have no choice but to site the plasma and projector screen ondifferent walls and at 90 degrees to each other and the room has beenconstructed to accommodate this configuration.
I have been expectingthat the issue of changing the speaker delay timing would be my biggeststumbling block in finding an audio solution for the changing orientation ofthe room to suit the change from TV to Projector viewing. I believe I might beable to overcome this issue by installing eight, ceiling mounted,Speakercraft Time Five speakers (in addition to the sub-woofer) arranged in asquare and arranged with one speaker in each corner of the square and onespeaker half way down each edge of the square, thereby maintaining the speakerto listener distance even as the orientation changes.I had envisaged that Iwould be able to accomplish a 7.1 configuration with front speakers, sideeffects and rear surrounds. If you can envisage this "Square"arrangement, I had anticipated that the same speaker set could be used for bothconfigurations with only the definition of which speaker represented eachposition relative to the listener changing between the two orientations ie thespeakers would all be similarly specified and their role would change with thefront left, centre and right speakers for Plasma viewing would become the frontright, right effects and right rear speaker when watching the projector etc... I have prewired two speaker cable runs to each speaker point to allow switching of configurations back in the cable closet if that is required.
I had hoped to connect each speaker twice using the twinned pairs to each point with a 12v DC fired switch to select either speaker configuration A or B depending on which display (and therefore orientation ) is in use. With this configuration, I had hoped to use a single amp/receiver, such as the Denon AVR-4810 with all sources connected to it and one its HDMI Outs connected to the 1080p plasma and the second HDMI Out connected to the 1080p Projector. I am however struggling to source a switch to take the 7.1 speaker out's and patch them to the A and B speaker wiring. I appreciate that without a drawing it is difficult to envisage, but I hope the above is intriguing enough to spark the imagination of the experts who peruse this forum.
I am sorry if anextended message,such as this, to the forum is inappropriate, but given that Inow have the structure of the room in place and am seeking to procure the techto make it happen, I would be grateful for whatever constructive advice isavailable from the well informed.
I thank you in advance
