Twin cone drivers. Why? And do they work?
Big Chris
400
After posting a pic on the oldest hi-fi thread, I see my old Hitachi portable stereo had twin cone drivers.
I don't know what purpose they serve. Obviously, there's no seperate movement as the smaller cone is glued to the larger cone, so I was just wondering what (if anything) they acheieve.
Can someone enlighten me?
The small cone in the centre is known as a whizzer cone.
It extends the upper frequency response range of the driver.
It was particularly popular in automotive applications to provide a pseudo-full range response driver. Could still be being used for all I know.
Sometimes it is augmented by a radiating dust-cap in the centre of the driver, further extending its response.
It's a cost-effective way of extending frequency response. Cheaper than a separate tweeter.
A quick google on whizzer cone will give you all the tech.
hth
Gary Mardell:The small cone in the centre is known as a whizzer cone. It extends the upper frequency response range of the driver. It was particularly popular in automotive applications to provide a pseudo-full range response driver. Could still be being used for all I know. Sometimes it is augmented by a radiating dust-cap in the centre of the driver, further extending its response. It's a cost-effective way of extending frequency response. Cheaper than a separate tweeter. A quick google on whizzer cone will give you all the tech. hth
Excellent. Cheers Gary.
I think those Beauhorn BBC2 Logo-alike speakers use twin cone drivers too.
Glad to be of assistance.
They're a very space-efficient way of achieving full-range driver response. IIRC thr Rehdekos also used drivers with whizzer cones. So they're not necessarily confined to low-end product. But they have obvious cost benefits over a two-way design such as an ICT, Uni-Q or a Dual Concentric driver.
I'd guess that the shape, size and mass of the whizzer can be altered to change the directivity and output characteristics.
Why is there never a transducer engineer around when you need one? 🙂
It's also a way to extend response without suffering from crossover distortion (or passive component insertion loss).
