TV on the wall - finally!
Lee H
336
Finally got around to having the TV properly wall mounted, adding extra sockets for each bit of kit, cables under the carpet/in the wall etc. Mrs H is happy as there's not a cable in sight!
It is indeed, good spot.
The TV is on a cantilever bracket so we can extend and angle it if need be
46"
I could never have done it this well, so we got someone in to do it. He put the rears up on the wall too and hid all the cabling.
Lee H said:
46"
It looks bigger to me - and it matches perfectly with the rest of the kit ..... He`s done a very good job , for sure.Great looking spot by all means...I`ve hidden my cabling too , but by using a piece of hardboard ( after sanding and painting it ) ... It doesn`t look nowhere near as good , but still better than cables hanging on the wall 🙂
is it the camera angle or is your t.v wonky?
very nice tidy set-up..
That's a good finish, how did the guy run the cables and hide it so well? Did they replaster the whole wall or drill holes at the studs and patch up afterwards?
i need to run some cables and wondering what is the best and cheapest way to do it myself.
After 2 1/2 yrs hes probably moved house.
Replaster/wallpaper paint is best but I did my bedroom tv by making big hole.behind screen and feeding cable below cabinet. I found a pipe bending tool fine to break into the eggbox constructed wall. Depends (ofcourse) on construction
Pipe bending tool? I'll do a bit of you tubing tonight...... :O)
If you don't mind me asking, what kind of socket do the cables come in and out of behind theTV? Are you able to easily run new cables to the TV?
