Dear all
I currently have a Panasonic X-HM21 CD player/speaker microsystem hooked up to its original speakers. Not a high end stereo, but makes a good sound. I'd really like to get a decent budget(ish) turntable (budget around £300 max) and at the same get some better speakers to both upgrade the microsystem and hook up to the turntable.
My thought was to hook the new speakers up to the CD player unit as usual and then connect the turntable to the CD unit using RCA cables.
My questions are:
-would this set-up work?
-can anyone please recommend a good turntable for £300ish which also has bluetooth in case I decide to use that at any time?
-what kind of new speakers would I need? I am a bit confused as to the difference between powered and passive speakers. Could I use powered speakers in the way I have described above?
-can anyone recommend a good pair of speakers for this purpose?
Many thanks in advance for any advice 🙂
Helen
My questions are:
Helen
