Turntable for Cyrus
Or maybe a seconhand Technics SL1200/1210 with a KAB 78rpm upgrade. Removeable headshell and direct-drive all in one unit!
Good point in you can find one already done (rare) otherwise you have the additional cost of shipping the deck to the States for modification.
Picking up on this again - clearaudio concept & a rega 78 appears as good as any option to play 3 speeds
if I go for a MM cart - for now - what would be a good phono stage to handle both tables / cart & take a future MC if I decide in the future
many thanks
many thanks
Sorry, missed you point there. Why do you need three speeds and what exactly do you propose to buy to enable you to do this?
The mention of MC and the notion of trying to play anything at 78rpm is clashing somewhat.
What exactly are you after?
3 speedsfor 3 records speeds
no turntable has a satisfactory / price sensitive 3 speed solution with an easy cart change - easier to switch the table - and for decent sound those 2 decks are cheapest / best solution I have found
so now a phono stage for both decks....
