Bit confused ... I thought the E30's could be used as a preamp as well and that you could adjust the volume on them but when I tried it didn't do anything so looked up the instructions and have pasted a screenshot below.
The "Note" at the very bottom .... "volume is set to 0db in DAC mode" .... I don't get that, it only has one purpose which is to serve as a DAC so it'sll always be "In DAC Mode" ...... or have I missed something?
I'm using a streamer via optical into the DAC (I could use coax if it made any difference) and line out, but from reading that though I'm guessing there's no way I can use the volume control on the DAC as my amp has no remote so would make it easier.
