rocketrazor
122
I have a Panasonic TH42G20 and notice that if I select the THX mode on the picture settings the actual picture zooms out and allows me to see more of a picture (ideal for films), if I then select Normal, Cinema or Game mode the picture zooms in and I lose a little of the picture. I was wondering if there was a setting I have missed so that it can be set on the Normal mode as well. Any ideas? Its a bit of a pain as I like THX mode for more picture size, but sometimes I need to put the picture to Normal mode as THX is to dark. Its not a great difference but to coin a well known phrase 'every little helps!'
TKratz
17
Yes, I believe Stu31 is right. It might be the THX mode has another default setting for overscan than the other modes. Try checking it out.
