RobGardner
As the owner now of three different QAS fuses I have to say I am delighted with the results of replacing the standard 13 amp busman fuses in my system with them. As I have never blown a fuse on any of my hifi over the last 45 years I don’t worry about a QAS fuse blowing ( but reserve the right to be irritated if one does). Interestingly they are rated at 13 amps, when many years ago I tried a Hifi tuning fuse it was only rated at 10 amps. I don’t remember it having any impact at all and now can’t remember where it is or what it’s in.
Owning examples of each of the three fuses in the entry range I can say that there is a significant audible uplift in sound quality as you move up the range from black to yellow. The black is already good and the blue and the yellow even better.
I, like many of the contributors to this thread, find it hard to imagine that the top of the range fuses will justify their expense, but I am open minded and come the lottery win, would have my butler fit several to my system.
The acid test is when you remove any tweak and go back to what you originally were listening to, do you miss the tweak more than the money! In this case I missed the fuse. Many an item has failed this simple test.
How would I rate the difference in using these fuses? Like a serious upgrade to a key component or interconnect or two.
Just for those that are interested, I use a black fuse on my 4 drive Qnap NAS drive, I was genuinely amazed at the difference in the quality of the audio stream following this simple tweak. I was expecting to hear little if any difference.
A yellow fuse on my Isotek Titan G2 power conditioner means I can share the benefits of this fuse over many components as apart from the two main outlets it also supplies a Isotek 6 way conditioner. From the moment the fuse was fitted there was a large uplift in the sonic quality of my system. I know from previous experience that as the fuse “runs in” this will improve more.
I have a blue fuse on my Devialet Expert pro 220 which is plugged in to my Isotek Titan. This amp just seems to get better and better with each upgrade to the power supply and isolation.
I also have a black fuse on my AV amp Which is also fed from the Isotek Titan.
I make that about £400 on fuses and the results have been absolutely worth every penny. I’m no longer thinking about dual amping my Devialet or replacing my NAS drive with a hifi network storage device like an Auralic Aries G2.1 , I think I should say that cd’s ripped to my NAS now, by and large, sound better and more richly textured than anything streamed from Tidal and Qobuz regardless of format.
Do they make a sonic difference, yes! very much so. Will I buy more, almost certainly. Will I buy from further up the range? Probably not as the results are already excellent and I would prefer to have a black fuse in everything rather than a higher spec fuse in a single component. Will they stop me upgrading, of course not, I can keep the fuses and use them in any new kit.
The results that I have experienced are those elusive hifi objectives, improved detail, much better sound staging, more speed and snap. More natural voice tones, improved ambience. I could go on.
I have found that having the higher end fuse upstream gives the best results, and yes, they are directional and don’t improve things if you install them the wrong way around.
I was so amazed at the result that I started to think about installing shuko mains sockets for my hifi to avoid the need for any fuses at all, but I suspect the effectiveness is not just about the ‘fuse’ and there is something else going on. Even so I would be interested to hear from anyone who has stopped out their UK plugs and sockets for Shuko and if it made any difference?
I would suggest that if anyone has got to this point in the thread that they make their own mind up about the value of theses fuses and enjoys the creative writing of the posters (I certainly have) . Bottleneck distortion may be a real thing or it may just be marketing speak, but however they do it, these fuses work and I have heard enough of them to want to try them in other applications that may well scratch that upgrade itch.
Finally I did try the black fuse in my 4K Blu-ray spinner and Oled TV, initially I thought the picture was improved, but when I took the fuse out and ran the same clip again I really wasn’t sure there was any difference. My TV and disc spinner while using standard fuses are now ultimately fed via a yellow fuse and I have to say that the picture on my TV has never looked better and the AV system never sounded better.
