This Amazon Fire TV is interesting me
  • Start date
Deleted member 2457
whats the difference between Amazon Prime Video and Amazon Fire TV though? Thanks.
Deleted member 2457
spiny norman
293
Amazon Prime Video is the video-streaming service, Amazon Fire TV is the bit of kit you plug into your TV and connect to your home Interweb router to receive that streaming service.
Deleted member 2457
Cheers Norman! I don't need it then.
Series1boy
356
16
18,895
no you don’t, you should have all the streaming apps on your LG OLED
Deleted member 2457
Cheers Series, I have only just started using them - getting on pretty well with it too!
Benedict_Arnold
661
You get 90+ percent of the features if you have a smart TV, although possibly not the full 60 fps and HDR, depending on ether you stream, for example, Netflix or Hulu via the TV instead of the Fire box.
Deleted member 2457
Yep, at the moment I think I am getting just uhd. I am using the TV stream for Amazon Prime Video and NetFlix. I have got HDR and Dolby Vision too though but perhaps that was on NetFlix.
