BenLaw said:
strapped for cash said:
BenLaw said:
two structurally perfect films IMO
Can you define structurally perfect?
Probably not
😉 I've never studied any film criticism (whereas I'm guessing you have), so I imagine there's some sort of formal definition which I'm misusing. However, having watched a lot of films IME the vast, vast majority have some sort of 'structural problem'. Both The Third Man and The Sting I find (obviously very subjective) are (i) not too long, (ii) everything is in the right order, (iii) each scene and each thematic concept has just the right amount of time spent on it, not laboured but properly developed.
It's not misuse, as such, but there isn't anything approaching a valid definition of structurally perfect cinema. Indeed, different filmmakers use different stylistic and thematic conventions to achieve different effects.
For instance, the classical continuity system (or classical illusory realism) seeks to disguise filmmaking's artifice through conventions such as shot-reverse-shot, non-contravention of the 180 degree rule, sound bridges, and so on; while anti-realist techniques foreground cinema's artifice (Soviet montage, Godard's anti-realist output, or more recently Funny Games and Hidden).
Then you have techniques such as surrealism and expressionism which have nothing to do with representing reality, but seek to represent different psychological states (expressionism is the visualisation of character psychology, surrealists seek to represent the unconscious).
One of the interesting things about The Third Man is that it mixes realist and expressionist styles -- the former through location shooting and casting of non-actors (following trends in post-war Italian cinema), the latter through canted camera angles and chiaroscuro (legacies of German expressionism that also found a home in film noir and horror filmmaking).
I guess the point is that there's no such thing as a correct filmmaking technique, only overlapping stylistic and thematic conventions that can be used for very different purposes. Indeed, these assorted filmmaking conventions are continually re-appropriated and reinvented.
You mention things being "in the right order," but discontinuity is no less valid than continuity. Indeed, continuous narratives are very rarely truly continuous and use techniques to disguise shortcomings in this regard (temporal ellipses, for instance).
You're right that I spent seven plus years studying film theory and film history to doctorate level, though when I've suggested as much on here I've been accused of arrogance and met with hostility. Perhaps this post will provoke similar responses.
In truth, I'm useless at many things, though I hopefully learned a few things about film along the way. I'm absolutely certain, for instance, that I know considerably less about the UK legal system than your good self, or about medicine than BigBoss, or about aviation history than Chebby, and so on...
