I have had the old budget speaker of the year wharfedale diamond 220 to test and it doesn't live up to my expertations, dull, closed top,lack of open and clear sound with a bass that is missing,hardly couldn't hear it unless it's some sheffield drum test cd,edm like trance fm, even the good records didn't gave the bass more power,oomph so i didn't want to enhance the bass using the eq/tonecontrol.
My marantz PM6005 made my boston a25 have a sparkel to the tweeter that i wasn't used to and the bass isn't big tight and deep like a big high end amp with loots of power, but it can be deep and loud, even tight with the right cd/song, i do feel it's good at controlling the bass and like the clear and open sound,midrange which are good when listening to bagground music,tv,movies late night at low volume, dac(optical, coaxial input),phono stage,45 watt rms in 8 ohm,remote control,good sound, normal price 449£ got it for 249£
Marantz CD5005 149£ which is a very good price, have seen it for 100£ more, it's lighter then my old rotel rcd-965bx le discrete, easy to use,good response(play open,close,next track.....) silent when i use it (it can be heard when you open the tray or just when the cd starts to spin before theres music,not agressive and a loud sound at all, generally it's very silent),again open clear sound, can't think of some cons about the sound, it's just sounds good, especially for the price, only thing i would get is a better interconnect that's it, do use a better power mains since i had one i didn't use (clearer audio alpha one).
Boston a25 can handle alot of power, deep punchy bass,not boomy muddy bass using isoacoustics stands (you can here it's deeper then the wharfedales diamond 220) easy load (amp NEVER gets hot) with a good amp a neutral top that's never sounds fattigue,open,clear (i know use those words alot to descripe who it sounds ) and a wide sound from the midrange. Boston a26 just have a bit deeper, more bass,higher sensitivity and power handling, great for those who want a bookshelf speaker for a big room or those who love to play loud
Audioquest dragonfly is a good little usb dac, havn't had anything to compare it against, but reviews say it's a great budget dac for a pc,can't go wrong with the dragonfly if you look for something not more then 100£
All great products, i was a bit disapointed about the wharfedales dull sound(top) and lack of bass.
There are a bigger market for budget amps,speakers,cdplayers,dac's,turntables,cable..... then there is for ridiculous expensive hifi parts almost no one can afford, even some budget amps,speaker.... of the year can be a bit disapointing do to a mediocre sound quality or just a bright,harsh sound, could also be a boom bass where frequency responce sometimes is a combination of both, like a smilie, lot's of bass/treble that easily can led to a fatigue sound (worst thing ever).
http://www.planetofsoundonline.com/pages/why-is-my-system-hurting-my-ears
The point in this thread is to discuss what budget hifi parts that actually sounds good and not just bright,harsh, alot of bass or a combination of both, those hifi budget parts that if you choose the right parts just makes you wanna listen to music all day and won't be embarrassed telling your friends that you have,if they just know a little about hifi they would know it sounds good, even if it's just a cheap budget amp,speaker,cdplayer.......
