Technics su-v470 amplifier speaker connections.
Hi All, Does anyone know if any banana plugs or similar can be used to connect to the speaker connections of this amp please ? i've had some chord carnival silverscreen speaker wire terminated with chord plugs but they won't fit in the holes as there too small (No bungs in there by the way :shame: i know all about those) so i've had to cut the chord plugs off and wrap the wire around the posts |( . the holes only look about 2 or 3mm wide ? .....if you pop suv470 into google images you will see the speaker connections for yourself. Many thanks Chris.
