- Aug 10, 2019
- 2,556
- 5
- 0
Well I just won an audiolab 8000x7 on Ebay (580 beans, yay) but I have reservations about the power supply inside it. Same size as the 8000M's. Does anybody know what voltage these amplifiers operate at. I'm thinking I could get ahold of a nice phat transformer (or maybe the 3.5KVA transformer I have will work, 48V output, probably too high) and some beefy caps to give the amp plenty more juice. I've had trouble getting ahold of circuit schematics for amplifiers in the past (tried to repair a Cambridge Audio A1, suceeded in the end by working it out from the traces :O). Having read aocuple of reviews thats *gotta* be the weak point of the X7, not having enough juice on tap. There is only 20k mF of smoothing on the input too. I'd love to get ahold of more details, like if it's a switchmode PSU or not. Anyone know? I'll have to email audiolab... but I guess I'll plug it in and try it first😉 Second question, about bi-amping. I have my existing 8000P so I'll bi amp my GR20's as fronts. Given the 8000P is 100W and the (bridged down to a X5 amp) front outputs on the X7 are 150W, would it be better to use the X7 outputs for the bass and the P for the treble... bearing in mind that the P is gonna have a considerably better peak current capability (40A vs unstated*) that the X7 which screams bass. The other thing is the X7 doesn't allow passthrough, but the P does so it has to be first in line on the biamp chain. * 40A peak into an 8 ohm load = 320W for the 8000P: X7 stated peak is 120W, meaning 15A or thereabouts.
