Tannoy Eyris 2 vs Ma Rx6
eoin_g
Hi Guys,
I'm looking to buy my first pair of decent speakers. My.budget is small so I'm looking at buying secong hand. I have the option to purchase a pair of Eyris 2s or Rx 6s, the Rx 6 being a little more expensive. Any advice on which was be the better option ?
Thanks,
Eoin
Hi, that ks for the reply. I have ordered a Yaqin mc30l. Unfortunately I can't listen to either pair before purchase. I listen to a bit of everything, but mostly blues and Jazz.
Thats a tube amp. I believe? If so i think you need to be careful about what speakers you buy. Did you buy it on ebay?
Yep it's a tube amp with 45watts per channel. Yeah I ordered it from eBay. Reviews online seemed good.
Both those speakers are fairly sensitive so in theory they should work with your amp. But I will let others give their opinion as I don't much about tube amps.
How much are they asking for those speakers?
